https://happypeoplepickeball.com
Hi, I am having trouble with the the Ad not being inserted into a post. I have pasted the adsense code into the theme support area for inside an article at paragraph 2, but when I try to save the page, it hangs and it never saves. Thanks!
In the cloud templates, you can add the ads when you edit the post with TagDiv Composer in the element called “Single Post Content” in the tab ADS. Documentation here: https://forum.tagdiv.com/article-ads/
Hi! I followed your instructions and added the adsense code inside of a Single Post Template. The ad did not populate, please see attached. Any other ideas? Thank you!
Save and view the results on your frontend.
If the AdSense code needs to be set between head tags, this can be set in our theme in Theme Panel -> Analytics/Js Codes. Example: https://prnt.sc/1tju9qf -> https://prnt.sc/10jk7fq
