adsense duplicate problem
Im trying to add Advertorial custom code (adsense) into right colum (Homepage). When I do so, adsense duplicates itself. When I add 2 adsense codes, I see 5 adsense advertisements on my homepage. I cannot solve this issue.
website: islamekseni.com
isse: https://imgur.com/a/i1SHtmC
When I add codes 1 and 3, it automaticly adds numaber 2 and 4 as well. Therefore, when I add two adsense codes, I see totaly four codes. (also no:3 ad seems to be corrupted.)
Hello !
You can use an Adbox element in your sidebar and insert the adsense code into it: https://www.youtube.com/watch?v=fa7GenCHcBU&t=1s
Ive already added an adbox into row(right). Im encountering the problem with this method. Rather than adding the adboxes into row, are you suggesting me to create a New sidebar and retry adding the codes into sidebar?
By the way, I’m not having problem with the theme usage. I’m just trying to find a solution for this adsense crush and looking forward for a solution for this issue. As I have mentioned before, when I add 2 adsense codes, I see 4 ads on my homepage.
Hello !
Unfortunately, For this you will have to contact Google adsense support for this.
Thank you for your understanding !
