Adsense Exchange problem
i have this AdSense code
<script type=”text/javascript”><!–
google_ad_client = “ca-pub-1234567890123456”;
/* Citypatras.gr / 336×280 */
google_ad_slot = “1234567890/1234567890″;
google_ad_width = 336;
google_ad_height = 280;
</script>
src=”//pagead2.googlesyndication.com/pagead/show_ads.js”>
</script>
But the Custom ad print this without adslot:
<script type=”text/rocketscript”>
var td_screen_width = document.body.clientWidth;
if ( td_screen_width >= 1200 ) {
/* large monitors */
document.write(‘<ins class=”adsbygoogle” style=”display:inline-block;width:300px;height:600px” data-ad-client=”ca-pub-1234567890123456″ data-ad-slot=””></ins>’);
(adsbygoogle = window.adsbygoogle || []).push({});
if ( td_screen_width >= 1019 && td_screen_width < 1200 ) {
/* landscape tablets */
if ( td_screen_width >= 768 && td_screen_width < 1019 ) {
/* portrait tablets */
if ( td_screen_width < 768 ) {
/* Phones */
</script>
data-ad-slot is empty.
Can you fix it?
Thanks a lot!
this is right. I’m a premium member on AdSense, and this code is from Premium Account.
AdSense Send me all the premium codes by email.
if you want just tell me where is the function who fetch and extract adsense properties.
Thank a lot.
I understand. Have you tried using it just like this: google_ad_slot = "1234567890";?
You can find it here: http://screencast.com/t/7SlL7upl
the two numbers is differents.
i make change on pattern and now it’s ok.
preg_match(‘/”([a-zA-Z0-9\s]+)”/’, $explode_ad_code[1], $matches_add_slot)
to
preg_match(‘/”([a-zA-Z0-9\/\s]+)”/’, $explode_ad_code[1], $matches_add_slot);
Now include the symbol “/”.
Thanks a lot!
