AdSense Help
Every time I enter my AdSense Codes into the Theme Panel and test/refresh the codes disappear. Why? I have linked Google Analytics, I have claimed in Google Web Master Tools… Why is this happening.
Update, I have deleted the theme and reloaded… Still not working… I have built two other sites to near the same specs and AdSense work on those sites. There I something I am missing… PLEASE HELP ME
If you reinstalled the theme and the issue is still present, then something else is causing problems. Check the theme system status and see if the parameters displayed there are set according to this guide
You can ask your hosting provider to make the changes if needed. Also in some cases the admin-ajax process was denied or forbidden by the server which causes such issues in the theme panel. This is a similar topic
– https://forum.tagdiv.com/topic/cant-save-theme-options-2/
Anyway just to get a tech support rep to log into my site and poke around. Update what needs to be updated? I am running Newspaper on 4 different sites, all set up very similar and this is the only site I am having issues with.
If you still encounter issues, please contact us on our email address at contact@tagdiv.com and provide a link to your site and wp-admin (login information and admin rights) so we can login and investigate. Please also include a link to this conversation.
I sent an email to contact@tagdiv.com, do they only work during weekdays? I have not heard back from them. I emailed them Friday night.
replied via email
I dont have anything in my inbox 🙁 sent a follow up.
