AdSense in article auto ads are not showing in the Gourmet Pro single post template that I use on my site. Is this a problem with AdSense? or is it with your theme? If it’s the latter, does it mean that in article ads can only be added manually via the “Your ad code” boxes in the TagDiv composer?
Hi Edged,
There is no problem, just make sure that you have set the auto ads only once, because is not allow more the 1 auto ads. As for the Gourmet Pro prebuild website this is made with cloud templates, therefore the ads need to be set with tagDiv Composer on single post content in ads tab -> https://i.imgur.com/4hfOlNm.jpg but as I said before, please use only one auto ads, do not call it more then one time, because this will be set randomly there AdSense consider that is the right place, for the rest of ads, use normal ads.
Hello, I don’t understand what you mean by this “just make sure that you have set the auto ads only once”. I added the Adsense auto ad code to my Headers and footer plugin. Why would it be set more than once unless adding non-auto Adsense ads manually? As for the Gourmet Pro, so it doesn’t allow for auto ads meaning that I can only have 3 in-article ads max?
This reply was modified 5 years by
Edged.
Hello, this answer is not clear. Can you please make sure to answer all the questions above clearly, please. This is starting to get frustrating that I can’t get straight answers as I need to finalize the design of my site.
Edged.
If you are using AdSense auto ads, you have to insert the code in only 1 place. For example, insert it in Theme Panel – Ads – Header Ads. And that is the only place where this code should be.
If you insert it in more than 1 place, the code will be broken or will not work. Based on your most intense areas where users put their finger (on mobile) and cursor on desktop, Google will autoplace ads so that you will get maximum out of them.
Please make sure that after you are making any changes, clear your cache and test your changes on an incognito page.
You can if you want to switch to standard templates but that would be a shame when there is so much more potential on cloud library templates.
Please let me know the result of the instructions above! If this doesn’t work please contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
Our team will take a look ! Please note that at the moment the support is a bit crowded. Replying may take up to 24 hours.
Thank you for your reply, but you have answered the question that I know was already correct but didn’t answer my primary questions. So let’s do it this way.
Question 1:
Currently, only one Adsense auto ad is showing at the bottom of my post page and not in the article content itself. So my question is, does Adsense in article auto ads work on cloud templates such as Gourmet Pro single post template? (A simple yes or no please)
Questions 2:
If no to question 1, does this mean that I can only add 3 in article ads (Article inline ads) max manually via the 3 “Your ad code” fields in the TagDiv composer if using cloud templates such as Gourmet Pro single post template?
Question 3:
If question 2 is yes, do you have any plans to allow for more than only 3 in article ads to be added in the future? or better yet auto-populating the ads in the article based on every few paragraphs specified and the overall number of paragraphs in the article?
Q1. Yes.
Q2. does this mean that I can only add 3 in article ads You can increase that ad space number by editing the code of the theme.
Q3. This is on our developers to do list but unfortunately at the moment there is no ETA on it.
I hope this was more helpful!
Hello, thanks for your reply.
But, if auto in article ads work, why are they not showing between any of the cloud template article paragraphs or custom TagDiv page posts? I know I have set up Adsense auto ads correctly because they show up in between the posts of my search pages and at the bottom of all pages. But not in between the articles and posts content of the cloud template article paragraphs or custom TagDiv page posts.
Normally, the auto ads should display in a single post template, too. Using auto ads those will be automatically placed where they fit correctly => https://i.imgur.com/qX36kT0.png
Therefore the theme doesn’t have any control over those type of ads.
What I can suggest is to set some normal ads in your Single Post Content.
I have tried everything and I don’t know why auto in articles ads don’t work in the Gourmet Pro post template.
There is no way google Adsense is choosing not to put in articles ads in every single one of my well over 100 posts on my site but does so at the bottom of each one and other non-could templates.
further more 3 manual in article ad spots for articles 2000 words or far greater is a ridiculous solution, especially for a newspaper theme.
I have tried to be respectful, but I now believe that you guys have been wasting my time with these answers.
I will ask one more time, do Adsense auto in articles ads not work in the Gourmet Pro post template?
Please answer truthful and stop wasting my time so I can find a better solution.
Normally, auto ads should work for all prebuilt websites (all of them are made using Newspaper theme), but is possible to be some problems and that is why the ads are not display.
If you agree we would like to investigate this situation, for this please make a full backup to all files and database, and contact us via email at contact@tagdiv.com and provide the wp-admin URL and cPanel access. Also include the link to this topic in the email.
Hello, the login details have been sent to contact@tagdiv.com. I await to hear what you guys find in relation to this problem. Thanks
