Please check this documentation for Google Ads for WooCommerce -> https://woocommerce.com/products/google-ads/
Hope this will help you!
Please provide some more details about how you achieve the products page, if you use the tagDiv Composer then you can use the ad box element to set the ads were you want.
If you are not using the tagDiv Composer builder then you can set the ads in sidebar , you need to set the sidebar in Theme panel> Template Settings -> https://www.screencast.com/t/ZMfUexAY
In Newspaper v9.7.3 if you want to add some ads in product post/page you need to edit these files wp-content/plugins/td-composer/legacy/Newspaper/woocommerce/archive-product.php and single-product.php in prev version these files can be found in wp-content/Newspaper/woocommerce/archive-product.php
We suggest you extend your support if you still need our help with your website or add extra keys that still have support.
Please check this article -> https://forum.tagdiv.com/cant-post-reply-support-forum/
Then you need to edit those files -> wp-content/plugins/td-composer/mobile/woocommerce/archive-product.php and single-product.php
and for an old version, please check this path wp-content/Newspaper/mobile/woocommerce/archive-product.php
