adsense problem
i applied for google adsense, and they asked me to past this code into the HTML of my website, between the <head> and </head> tags.
can sameone help me find this head tag please ?
there are two options (especially if you are under review for adsense):
1. From Theme Panel
– Copy your adsense code
– Open Theme Panel
– Click ads
– Chose one of those option, except Background click ads, then paste your adsense code
– Don’t forget to save settings
– Sit back & relax
2. From Text Widget
– Click Appearance & chose widgets
– Select (drag & drop) “text widget” into your header/footer/sidebar/whatever, depends on your site structure.
– Paste you code inside the “text widget”. Don’t forget to paste via html.
– Sit back & relax
If you are looking for the head tags they are here – https://www.screencast.com/t/VHAJnaPo
Code entered in this theme panel section will also be loaded there (also it will not be lost after a theme update)
https://www.screencast.com/t/pbHBw6woWpVd
