Adsense problem
I have added 3 adsense ad one in header 1, 1 article top and one article bottom. Only article top ads appears, others not.
Header and article bottom ads appears only when ı login blog.
I would be glad if you could help me.
Thank you
  • This topic was modified 10 years by Tezo.
Please check your ad codes as the theme only accepts standard adsense. Try the ad that works, the one from the header and set it to another spot and see if it displays. If it does, than most likely it is the ad code itself. If these other 2 ad codes are recently acquired ones, then it will take a bit of time before they will display.
Let us know how it goes and if the problem persists please provide more details about your ad code and provide a link to your website.
