Hello.
I try use code below to display banner on header. But it’s not displayed on desktop. You can see it here: fototips.ru
<div id="rontar_adplace_12172"></div>
<script type="text/javascript"><!--
(function (w, d, n) {
var ri = { rontar_site_id: 4165, rontar_adplace_id: 12172, rontar_place_id: 'rontar_adplace_12172', adCode_rootUrl: 'http://adcode.rontar.com/' };
w[n] = w[n] || [];
w[n].push(
ri
var a = document.createElement('script');
a.type = 'text/javascript';
a.async = true;
a.src = 'http://adcode.rontar.com/rontar2_async.js?rnd=' + Math.round(Math.random() * 100000);
var b = document.getElementById('rontar_adplace_' + ri.rontar_adplace_id);
b.parentNode.insertBefore(a, b);
})(window, document, 'rontar_ads');
//--></script>
If you reduce browser window to 700 px and less – banner is displayed.
I think problem in CSS, but i cant find it. Help me please.
I found that the problem in this part CSS code
.td-header-sp-recs img,
.td-header-sp-recs .adsbygoogle {
position: absolute;
margin: auto;
top: 0;
bottom: 0;
left: 0;
right: 0;
If I remove
position: absolute;
when banner is works, but the picture is not reduced with the screen
In order to use custom ads with our theme, please use this method: https://forum.tagdiv.com/using-other-ads/
Use the div’s provided so the theme can interpret the code as an ad and apply the proper css for it.
Thank you
Your ad does not work on my end at all so there could be something wrong with the ad itself. Please try to use a standard ad, like the one that comes with the theme:
<div class="td-all-devices"><a href="#"><img src="http://localhost/wordpress/wp-content/uploads/2016/03/rec728.jpg"/></a></div>
If this one works, then it means the theme works as expected and renders ads. You can try your ad in another ad renderer like the adrotate plugin and see if it will work like that. If it does not work even with adrotate, then the ad needs to be checked.
It works in sidebar, i use widget with Custom Ad – http://fototips.ru/praktika/kak-samostoyatelno-sdelat-kolcevoj-osvetitel/
tigruz.
