First of all I’d like to congratulate you guys on your theme panel so far.
I have a recommendation that would greatly benefit all publishers monetizing through ads:
Ad code insertion based on post category/tag.
This enables us, the publishers, to create custom targeted channels that will allow us to sell advertising on only one post category.
ex: I could set up separate ads on Fashion vs Travel
The implications are huge and we would gladly pay for this kind of premium feature!
Looking forward to your reply!
Thanks for taking the time!
hi,
thank you for your suggestion , we will talk about this.
for now you can create separate sidebars from category panel for each category : http://screencast.com/t/250ZvG1JU
then go to widgets , find your sidebars and drag [tagDiv Ad Box] from witch you select your custom ad : http://screencast.com/t/itg3ogxJt .
you can modify the theme to have as many custom ads as you like.
hope this help
Thanks for you message.
Radu A.
If you need more custom ads you have to edit td_config.php and add it like this: http://screencast.com/t/LjL18ZfbL Then just make add it in td_panel_ads.php file – http://screencast.com/t/UB3dwNgI68
Now you can add your code in Theme Panel > Ads – http://screencast.com/t/z3ROmJFEL and display it in your page – http://screencast.com/t/aNBwX5azB
