This morning I’ve updated one of my sites to 12.4. After the update, header and some page elements were gone (that is, showing TD Composer shortcodes), others were fine. The Cloud Templates menu item was nowhere to be seen. I wanted to try resaving the header for example, but couldn’t find it anymore.
What happened was this: TD Composer updated itself right after the theme update, as usual. But TD Cloud Library did not, and it was showing as up-to-date. On the next update run, I specifically forced it to update. Now all is well.
If you’re having problems after updating to 12.4, check to see if tagDiv Cloud Library is up-to-date. Try forcing it to update.
