Aesop Story Engine plugin dont normal work
Hi. I have use plugin Aesop Story Engine. But its not normal work.
http://aesopstoryengine.com/ Aesop Story Engine for wordpress story plugin. Its cool plugin. I have use my site.
After install my site Add New Gallery page ADD IMAGES not work. No insert image.
Please be careful with untested plugins as not all plugins work with our theme and when they create a conflict, they tend to break parts of the site. If you notice issues after you install a plugin then you have to remove/replace it. Here is a list of tested plugin: http://screencast.com/t/ty2kVL1VRu
If the plugin you want to use is not on this list, it means it has not been tested so we cannot say for sure what the result will be when you activate it. As most premium themes are not compatible with every plugin, you have to be cautious with every one you activate. If a plugin does not work with our theme when it;s activate, you have to move on to another as in most cases the implementation is very difficult to make and requires much time and effort.
