After clicking on “Save Settings” in theme panel, square icon keep spinning and thats it. No changes saved. It keep spinning until I reload or close page. I cant save abolutely nothing in theme panel. So button “Save settings” in theme panel not working at all.
Screenshot how it looks: https://imgur.com/DxEbPCu
I deactivated all plugins, tried in different networks, browsers, incognito modes. I tried I wrote to hosting provider support 3 times, they said that everything is perfectly fine.
Please check the console when you hit the save button and see if there is an error. With right-click -> inspect -> console -> select the error in the tab network -> preview, you can see the cause.
Please check this topic https://forum.tagdiv.com/topic/tagdiv-composer-does-not-save-only-content-of-homepage/
Please go to the network and select the issue; maybe you have a firewall -> https://i.imgur.com/87R8Eck.png
ok, I did it
this is what it shows – https://i.imgur.com/H4zGp2P.png
This is not the error; the error needs to be red.
I would like to take a look. Can you please contact us via email at contact@tagdiv.com and provide the wp-admin access?
