After Updated Mobile Menu Issue
Today I’m Updated Theme After That i Got Error on Mobile Devices Menu Not Showing For Mobile Users it Shows Click here – to use wp menu Builder But I’m selected Menu in Tagdiv Composer But Mobile Devices Showing That’s Error, But in desktop in Mobile View Showing Good, Not Working on Mobile Only.. Please Solve the Issue, SO I’m Downgraded to Previous version Everything Okay, But I’m facing issue in Newer Version of theme.
In Mobile Devices Showing Menu : https://prntscr.com/v0g11n
In Desktop Mobile Mode : https://prnt.sc/v0fz3o
This Problem Shows only For Home Page
Other Category pages working Good
So I’m Created Another Page on For Mobile Devices But menu Button Not Updating
Please See Below Screenshots
Selected Menu Button (https://prnt.sc/v0g7si) >> Menu Selected (https://prnt.sc/v0g8sx >> https://prnt.sc/v0g9u3) >> After Successfully Saved Page ( https://prnt.sc/v0gan1 ) >> I’m Clicked on Refresh Button ( https://prnt.sc/v0gc35 ) Menu Not Updating Showing –Select Menu Option– ( https://prnt.sc/v0gcvl )
Please See My Issue and Solve The Issue
I’m Tested In Anthore Website Showing same Issue https://www.viswamvoice.com/ This is My Website
https://prnt.sc/v0gh4v
  • This topic was modified 6 years by SVPrasad.
I think that you are using the mobile theme plugin, please disable it, also make user that the mobile page is set -> https://i.imgur.com/4BDVbf1.png normal the mobile should look like this -> https://i.imgur.com/2j3QkVX.png but yours is look like this -> https://i.imgur.com/1yQJjCi.png
i have only with menu even created mobile page template menu not saving it shows Click here – to use wp menu Builder https://www.viswamvoice.com/main-mobile/ This is Mobile Template But Menus Not Showing i have only problem with menu only https://prnt.sc/v0mti8
Only problem with mobile menu remaining everything is ok. Please solve the mobile menu issue please check my website and open memu https://viswamvoice.com Menu buttons >> Menu not showing
Hi SVPrasad,
If I understand correctly, you created a new content for mobile, using tagDiv Composer, but when you have set the mobile menu, did you choose a mobile menu ? make sure that you have made a mobile header and assign the header on both viewports -> https://i.imgur.com/VnEOBzQ.png -> https://i.imgur.com/89Z5U73.png
Let me know the results!
