After Updating to 6.1. Speed Booster still unhappy with plugins
I just updated to version 6.1. – first, thanks a lot for the quick update. You are awesome.
I am just curious about the behavior of the speed booster. In the new system status panel it is telling me that spped booster has a problem with severall plugins. I already deactivated az glossary index, seo images, animated gif resize …. each time a new plugin pops up as the next source of problem for the speed booster.
What shall I do? Any idea might help. I can’t deactivate all of my plugins just to get speed booster running.
regards,
julingn
What i done is don’t use it because it’s not working well with any plugins,i’m having the same issues and will not stress over it just keep it off my site till it get fix..
I’m still searching for a good solution for that plugin. A lot of people install the plugin without knowing what it does and after that they add 100 plugins and some of the plugins are not written ok. For example some of the plugins do not respect the google pagespeed recommendations of punting javascript at the end of the page and they just try to use jQuery in the middle of the page. This slows the site down and it also enforces the requirement that jQuery has to be in the header instead of the footer how Google recommends.
For example even Revolution Slider is written that way, not only that but they don’t use recommended WordPress methods to load it’s style and js. One may say that loading resources that way is bad BUT even jetpack (that is a plugin made by the makers of wordpress) doesn’t use standard ways of loading resources – you can find the jetpack hack in the speed booster.
I know this is causing a lot of frustrations but we don’t have a good solution yet 😐 .
To always enable speed booster, delete this code: http://screencast.com/t/RZLIOPUNdqh
@neakriti
thanks for providing the solution.
@neakriti
