Again WordPress reports problems with TD Composer
Dear Sirs. Again I disclose the conflicts reported with the TD-Composer plugin. My site got slow and this is the report I received:
Since WordPress 5.2 there is a built-in feature that detects when a plugin or theme causes a fatal error on your site and alerts you via this automated email.
In this case, WordPress has detected an error with one of your plugins, td-composer.
If your site seems broken and you cannot access your desktop normally, WordPress now has a special “recovery mode”. This allows you to safely access your desktop and investigate further.
When looking for help with this problem, you may be asked for the following information:
WordPress version 5.5.3
Current topic: Newspaper (version 10.3.7)
Current plugin: (version)
PHP version 7.4.10
Error details
An E_COMPILE_ERROR error occurred on line 64 of the /var/web/site/public_html/wp-content/plugins/td-composer/td-composer.php file. Error message: require_once (): Failed opening required ‘includes / tdc_config.php’ (include_path = ‘.: / Usr / share / php’)
Hello !
– admin url and credentials
– cPanel url and credentials
Our team will take a look !
