Ajax categories dropdown does not work
I don’t know when, but on our page stopped working ajax categories dropdown. They are shown, but when you click on them it moves page to up and nothing is filtred. We use them in Flex Block 4.
I’ve made a research why it does not work. I have tried turning off WP Rocket and Redis object cache, but no results. I’ve found out, that this code from your js (/wp-content/plugins/td-composer/legacy/Newspaper/js/tagdiv_theme.min.js?ver=11.5.1):
jQuery(".td-subcat-item a").on("click", function(a) {
a.preventDefault();
a = tdBlocks.tdGetBlockObjById(jQuery(this).data("td_block_id"));
!0 !== a.is_ajax_running && (a.is_ajax_running = !0,
jQuery("." + jQuery(this).data("td_block_id")).find(".td-cur-simple-item").removeClass("td-cur-simple-item"),
jQuery(this).addClass("td-cur-simple-item"),
a.td_filter_value = jQuery(this).data("td_filter_value"),
a.td_current_page = 1,
tdBlocks.tdAjaxDoBlockRequest(a, "pull_down"))
When page is completly loaded and subcategories are shown (they are some how lazyloaded) and I paste this code into the console, ajax categories works.
You can chek it here on homepage (e.g. section “Video”): https://www.inrybar.cz/
How to fix this please?
With best regards,
David Pavelka
Hello David!
We can take a look at this and investigate why it is not working for you. Contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
– cpanel url and credentials
