Using Current Version:
– Homepage has been set to “Optimize Preloading” of displaying additional news categories in Ajax Categories Drop Down
– Suddenly began displaying gray box instead of images associated with articles
– Switched to “No Preloading” and it solved the problem.
Tried to switch back and same issue. Cleaned all caches to no avail.
WORKAROUND: No preloading is fine for me, but others may run into this issue.
I am running into the same problem, only no preloading doesn’t fix the problem. The thumbnail loads on initial load, but when i use the ajax categories changer loads the post but not the thumbs. I checked the element in chrome devtools and the img tag is properly generated, just the image is not displaying.
Steps I already tried:
1. Force regenerate thumbnails.
2. Only Plugins that were installed are the one that come included with the theme. I also tried disabling each of them.
3.Tried both versions of preload and with out any preload. With either version of preload I got a grey box. With no preload I got a blank space.
4. Cleared cache.
5. On current theme version.
