Ajax Filter Label Order and Display
Hi Guys, the labels in my Ajax Filter using Tag ID’s are appearing in alphabetical order and not the order I type them in, am I missing something obvious? also is there any way we can make all of the filter labels appear in the ‘More’ dropdown filter tab as opposed across the top of the block and then inside the dropdown depending on how many we list?
Matt
Also, with the filter enabled the block displays the title even if we leave it empty as ‘Block Title’, can we just have the filter with no title?
Matt
Hello mattemkadia,
Unfortunately, our theme does not have such an option for it, sorry! Please notice that all available settings for Ajax filter are placed here -> http://screencast.com/t/REfApkiCo and any extra option involves custom work.
If you want to display more levels in our theme and if you are not aware of the steps in this regard, please consider hiring a freelancer/developer to help you!
