Ajax filter on a 'Block' prioritised over primary filter
Hi, I am using ‘Block 11’ and trying to filter a primary category (News) then set the ajax menu to sort secondary categories that I am treating as subordinate (Australia, New Zealand, Canada, France). I assumed it would show/filter a list of posts categorized as News and sorted into menu options as All, Australia, New Zealand, etc.
When I use the settings below, the primary category filter no longer works and ‘Block 11’ shows posts from another primary category (Sport) so I see anything categorized as Sport and Australia, New Zealand, etc in the list as well. The ajax seems to be taking priority over the primary filter.
Filters
Category Filter – [News]
Ajax Categories Dropdown
Filter Type – [Filter by Categories]
Show the Following IDs – [2, 3, 4, 5] (In this case Australia, New Zealand, Canada, France)
Is this working as intended or have I missed a setting somewhere? Any help would be appreciated.
When you filter the posts after a category, all posts from all categories will be display if these are part from the category you set in the filter.
-> https://i.imgur.com/vhbNyhw.png -> https://i.imgur.com/mZnr2Gn.png -> https://forum.tagdiv.com/block-settings-guide/
Hope this will help you!
Hi, does the Ajax categories dropdown also work if we add a second type of filter which is a filter by tag slug ?
Let me explain :
On the first block on this page https://devenirbilingue.com/promotions-reductions-apprendre-langue/ I’d like to show all posts from multiple categories with the tag “promotion”. I used the filters ans it works. However, I tried to use “Ajax categories dropdown” with a filter by tag ID (several languages tags to offer a selection of the posts for each language). If I click on English I should see the post with the tag english, which are part of the multiple categories selected for this block, and which have also the tag Promotion. The result is different: I can see all posts with the tag English, from the multiple categories I chose, but the filter Promotion is not taken into account any more.
Is it because I cannot use the Ajax categories dropdown with multiple categories filter AND a tag filter ?
Emma
Hi emmalabbe,
The AJAX CATEGORIES DROPDOWN is not working with these filters -> https://i.imgur.com/PwNWHkn.png this -> https://i.imgur.com/m6ehCs9.png is a separate filter that will be set when you choose a category, this will display all the posts from that category.
