Ajax filter problem
Hello.
I want to show the sub category in Tagdiv Composer Block, but it doesn’t work well.
http://poohsiro.com
Like attached img, I type the category slug in “Ajax dropdown – show the following IDs:”
img link : https://drive.google.com/file/d/16iXixoIdoF67EMlJ3YEZbtjG37PSaqtX/view?usp=sharing
But in this img, only “명언 시리즈”(slug : speech) menu is appeared. Of course the other category has post, but it doesn’t work now.
img link : https://drive.google.com/open?id=1Esu3uG7tcGStMKudFbEYMwTCs0R7nmV6
I want to show this sub categories in block 2.
Could you tell me the solution, pls?
  • This topic was modified 8 years by gh03083.
The ajax menu will display categories by ID, each category has a unique ID
https://www.screencast.com/t/TzNMHu6CnDJ8
https://www.screencast.com/t/l84aiFa0Fi
Please use the category ID’s not name or slug, it will not work with those values.
I am having the same issue. The Ids are there but only “All” will display. I am having this issue with all blocks ( with different categories)
https://drive.google.com/open?id=1vJop1AZCyT4GH32yFZgC7gXHA80f9Kav
https://drive.google.com/open?id=1Z6_8iJ_iDRmNw02ox44RkVfWbXv62MkL
I see from the screenshot the filter type is by tag, not category. Set it to filter by category if you are using category IDs, or use tag IDs if you want to filter by tags.
Thats was it, thanks!
