I have problem with Ajax load (subcategories in mega menu not load posts) when using iThemes Security PRO option “Force SSL for Dashboard”
Public part of site is visible ovet http but i want admin dashboard to have acces only over https. Force SSL for dashboard is very important for me.
I know that iSecurity not in list of tested plugins but want to know did any other user have same issue or maybe tagDiv support have some solutions?
Check in browser console if there appear some errors related with a possible conflict between content delivered from http to https. Usually should be 403 or 404 error.
We didn’t tested the iSecurity plugin with the theme so I am not aware of its functionality, but if this happens only when you have it active probably it conflicts with some of theme’s scripts.
