Ajax Page Navi Problem
My website is http://www.bilgekalemi.com My problem is : ajax page navi doesn’t work. You can see on the homepage. In slide and block it doesn’t work. Also in the main menu, there are mega menu problems. When i click next it make my website adress: http://www.bilgekalemi.com/#
Can you fix this problem.
I fix it ok. The problem isis about a plugin but which plugin i couldn’t find.
