Alignment problem
I have a problem with the homepage. Take a look at http://applenew.us and you’ll see, one part of the website is on the left side, not centered, and I can’t find the problem.
Thanks for your help.
Caesar
I’ve checked your site and noticed that you’re using a full width roe to display the big-grid. Make sure you set the starch option to default value in Visual Composer: http://screencast.com/t/c7NOlNLHLGF clear all caches and test again.
Let me know how it goes and if you need further instructions please provide ore details and we will reply in shortest time possible.
  • This reply was modified 10 years by Andrei L..
Thank you very much, I knew I made a mistake somewhere, but I wasn’t able to find it. Though it’s simple like that. I have another questions:
1. is there an easy way in this template how to make the Google Fonts latin-ext compatible? The think is they look fine in Google Chrome, but not so in Mozilla Firefox.
2. I activated this theme on this domain to get to this forum, but I realized later that I might have been too quick. This domain is only a test domain and the theme will be used on another domain – existing website. Test domain will be redirected to the other domain. Will I get a problem with the theme activation on the other actual domain?
Thank you very much for your time and tips.
Regards Roman
1. I’ve checked your site on both Chrome and Firefox browsers and I didn’t found any issue with the fonts. If you still have this issue please provide a link where I can inspect this closer.
2. You can use each theme license just on one product (website/domain) these terms are set by Envato here – http://themeforest.net/licenses/standard – http://themeforest.net/licenses/faq They specify that you can use one license for one product (website/domain). You can use it on multiple test sites and on multiple subdomains as a part of the same site-product. However if’ you’re using the theme on a test domain you can also use it with the same license on your live site as this it’s considered part of the same project.
