Hi 1fsij,
The block elements are very limited, these have only few options for customize, we recommend to use flex block, the are more complex and has a lot more options to help you to achieve what you need -> https://i.imgur.com/F12uGce.png
Also please provide some more details about what you want to achieve, in this way I will be able to help you with the right indications.
Thank you Calin for the reply.
I already fix it. Just a custom css then block 11.
What i did is 1 put five block 11 then I limit them to post one article. I gave them a class for each even number. Then this class will rearrange the image and text position.
this will render block 11 to text and image, then image text vice versa
