amp ads and Related Posts Module
1. Google for mobile to mobile ad allows 320×50 when I create this size and pass the client and slot to the Header Ad of the AMP setting then it does not take the 320×50 into account, it makes it bigger and square.
2. I’ve deactivated creating photos for 265 x 198 and I do not have such thumbnails. How do I make another choice or totally remove your own Related Posts Module and place a Matched content unit;
3. the already existing post will appear on google as amp OR applies only to the articles I add by activating the plugin afterwards?
4. embed code Instagram does not display the post with the photo. no solution?
1. Indeed the ads will be 300×250 in size, there is an option to make them fixed to 100px height only
– https://www.screencast.com/t/ZIZ7WWbHk
2. The related section will be displayed on AMP pages as long as it is enabled for desktop in the theme panel. Disabling it on desktop will disable it on AMP pages as well. The AMP plugin does not have a matched content dedicated option. You can make tests with such codes, we have only tested default Adsense ads on AMP.
3. When the plugin is enabled this will be seen in the post page source
– https://www.screencast.com/t/h1dOe33Omm
Then it is up to Google to index the pages.
4. According to AMP developers Instagram embeds have these requirements
– https://www.ampproject.org/docs/reference/components/amp-instagram
the notification for cookies
it does not appear. how can I show up?
There is no setting in the tagDiv AMP plugin for cookie notifications, neither there is in the main theme. If you want to implement this for your website, here are some possible solutions I found online
– https://ampbyexample.com/components/amp-user-notification/
– https://www.iubenda.com/en/help/posts/3182
