Amp auto ads problem.
Hello. We correctly implemented our codes on our head and body, yet mobile amp theme do not shot amp auto ads. Do we need to add our codes in theme panel as well? We only did it manually with FTP to plugins/amp/templates/html-start.php.
For testing: https://www.birgun.net/haber-detay/universitelilerin-5te-biri-calisiyor.html?amp
Thank you for your help.
You only need to enter the auto ads code in the theme panel now
http://prntscr.com/n0g6ll
The ads should appear after a while. We have tested this on our end and the ads are being served. Be sure to test with the mobile emulator in mobile mode or an actual mobile.
We did that too, yet there is still no ads.
Here in page source, you can see that codes are implemented: amp
Still no idea why they don’t show. We’ve waited whole day.
Currently I see ads appearing – http://prntscr.com/n0to68http://prntscr.com/n0to9a
http://prntscr.com/n0tocm
They say it usually takes about 20 minutes before the ads appear, but I have seen cases where they only appeared after 2 days.
