Hi guys, I’m using the AMP plugin.
As you can see the colors (and layouts) of desktop and AMP versions are quite differents.
Post desktop mode
Same post AMP version
The colors in particular are quite bad.
I asked to the AMP plugin support and they told me:
It looks like you’re using the Newspaper theme by TagDiv, which features its own AMP templates. These templates use the same design and styling for mobile as they do for desktop. Your team developer should be able to assist with this.
How can i make the two versions the same or at least as similar as possible?
Hello !
I’m not sure I fully understand the issue here. This is how your desktop looks like: https://www.screencast.com/t/zeWbxHRqEXZB
And this is AMP: https://www.screencast.com/t/qLMgKXUpK
Everything seems to be in order, are we missing something ?
For example the “quotes” have different colors. Is it normal?
It’s a minor problem, but maybe is easy to fix.
That seems to be something external that overwrites our setting. Please try this css code: .td-post-content blockquote p{
color:#4db2ec!important;
Please insert the code in here: https://www.screencast.com/t/RYxlLFic9
Let us know the result !
