AMP compatibility problem!
After the last update, the amp pages do not work. There are a lot of mistakes. Not what entries look like on the attached screen. I am asking for help, because I can not imagine having a modern site without the AMP version, which is currently the required standard.
When configuring the AMP plugin, a message appears:
“Paired mode activated! However, there was an error when checking the AMP validity for your site. Internal Server Error”
https://ifotos.pl/z/qwaerxh
  • This topic was modified 7 years by Arlink.
Please use only this option -> https://www.screencast.com/t/rdGNpNA8
Also please check our documentation for amp from here -> How to Make an AMP ready Website with Newspaper Theme -> https://tagdiv.com/amp-newspaper-theme/
It does not solve the problem. AMP pages are now visually unattractive and do not fit the Newspaper theme. The earlier AMP plugin was much better. I discovered that the problem stems from wpDiskus. I suggest that the APM websites only show the “Leave a comment” button and after clicking on it the topic would go to the standard version, where you could comment on the article. wpDiskus extensions have a huge impact on the popularity of websites and should not be underestimated…
Can I disable discuz comments on AMP pages with a custom code (in the mobile theme options)?
  • This reply was modified 7 years by Arlink.
This https://www.screencast.com/t/s9vhLEx8Smx is a advertisement/remember that you have activate this option -> https://www.screencast.com/t/6DWH6xgV8 and you can not longer deactivate the amp on post/page, this will do automatic, if you deactivate this option https://www.screencast.com/t/6DWH6xgV8 you’ll have again this option -> https://www.screencast.com/t/53Lam7ZfRh -> https://www.screencast.com/t/lT8KVP3FqyT
You can use a custom code to hide them, if you need help with this please provide me a link were to inspect this and I will try to help you!
