Hi everybody,
for AMP sites, I don’t see any possibility to change the font for comments. Although I set other fonts, that does not apply to AMP site, as you can see here: https://imgur.com/a/55gKYTN
Also, the language is set to English at some parts, for example search: https://imgur.com/a/anKvBMU
How can I change these? Thanks a lot in advance.
thanks a lot for your help. Here is a link to an AMP site: http://test2.skispringen.com/2020/04/andreas-wellinger-erleidet-schluesselbeinbruch/?amp (login with user / userpasswd)
The translations setting in Theme Panel does not affect the AMP page – for example Search. So I already translated “Search” into German and it works for the normal website, but on AMP it’s still English.
Indeed the font style is not apply, what you can do is to use a custom css like this one
.comment .comment-content, .comment .comment-content p {
font-family: "Open Sans";
If you are using the mobile theme plugin with amp, then you can set it here -> https://i.imgur.com/GBLhxs0.png
In amp version is set a placeholder for Search…, this can be change only in theme files wp-content/plugins/td-composer/mobile/header-amp.php -> https://i.imgur.com/Vv97OdL.png
