Website url https://bionetworth.com/ please try opening in mobile here is the screenshot”https://prnt.sc/MtLkFEoG8AKQ”
You have a header template from Cloud Library, then you need to edit with tagDiv Composer https://www.screencast.com/t/Y5j6ArY8Ug, select the logo and set there the image, make sure that is set to show and delete the logo text or SVG code-> https://imgur.com/ve11Fwt -> https://forum.tagdiv.com/add-logo-newspaper/
For mobile please edit with tagDiv Composer, select the viewport on phone, select the header logo and change it => https://i.imgur.com/cR7F0v4.png
Also, if the logo is in a modal popup, you need to edit that page to change the logo.
