How be possible to show the mobile the in AMP?
If you see the AMP vertion looks like this https://agravia.gr/?amp https://prnt.sc/w7390v
and the mobile theme looks as main design that i have https://prnt.sc/w739s4 .
In AMP settings i try everything but did not fix my problem. https://prnt.sc/w73alw
How can use Mobile theme design in AMP also?
Hello !
As you can see here https://www.screencast.com/t/pAapqOtp Mobile theme is showing on your amp page.
Hello
I allow myself to intervene on this ticket because I have an AMP duplication problem. The google AMP test tells me that my AMP version is valid. However I have all my urls which are accessible at the same time via /? Amp and /? Amp = 1 of the blow SEMRush makes me report all these duplications.
I am in “Standard” mode with automatic redirection from the mobile to AMP.
In the theme settings I am in AMP
My website : https://www.handirect.fr
Thanks !
This reply was modified 5 years by
nicowebmaster.
Hello !
That is because this option is enabled: https://slack-imgs.com/?c=1&o1=ro&url=https%3A%2F%2Fi.imgur.com%2F649ocos.png
Please disable this option and let us know the result !
Hello
I disabled this option. I did a test by loading the page of an article in /? Amp and /? Amp = 1 and both are displayed
Nicolas
Hello !
We need to take a look and see what can be done there to see if a fix can be done in order to fit your needs.
– admin url and credentials
Our team will take a look !
Please note that at the moment the Support team is not 24/7 available. We answer the topics from Latest to Newest Monday – Friday from 08:00AM to 05:00PM GMT+2
