AMP other language problem
I have a problem with the AMP plugin. There is no problem with the default language. It works as I want, including homepage and inside pages. But in other languages I have a problem like this. Homepage AMP is not coming. The inner pages, on the other hand, work as AMP without any problems. For example;
https://www.konsultasyon.net/es/?amp does not come as AMP
https://www.konsultasyon.net/es/sindrome-de-enterocolitis-relacionada-con-proteinas-alimentarias-seipa/?amp this is true.
I can’t solve it and I’m waiting for your help.
Thank you
After I made a test with a amp validator I get those results -> https://i.imgur.com/T6wEyPq.png -> https://search.google.com/test/amp?utm_source=gws&utm_medium=onebox&utm_campaign=suit&id=tl-hWPdqzH5hEmnzmh4cng
Please check the amp settings on that language, also make sure that you do not have any plugins or code that can interfere.
Let me know the results!
I have already tested from that address and then applied to you. Please review and support? I have been using amps with the same features for months. A few days ago he started to give an error. You are the developer and you need to provide information about what caused this.
Make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv plugins, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
If there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel. We will take a look. Include a link to this topic in the email.
