amp page problems on mobile
Hi, I’ve had the newspaper theme for some time, and I installed the mobile theme plugin. I followed all your instructions on the forum tutorial to the letter, but the amp pages only look good on desktop. normal pages on mobile can be seen well, but AMP ones can’t. A message like this comes out: sorry you have javascript disabled to see this page as it meant to appear, please enable your javascript. So when I went to my mobile browser I activated JavaScript, an option that was already active. Despite this, the problem persists. I’ve looked online for a way to resolve this, but everyone says to do it from settings etc. Do you have any idea why AMP pages on mobile, with the necessary plugins activated, give that error? Try it yourself, for example, from this link https://www.lottogazzetta.it/numeri-spia-per-il-lotto-del-30-01-2024-2/amp/ awaiting your response, best regards friendliness
Check this thread: https://wordpress.org/support/topic/sorry-you-have-javascript-disabled-2/
From my point of view, if you don’t use the Mobile Theme plugin, then there is no reason or benefit to AMP. Unfortunately, AMP is not working with the cloud templates because the AMP’s layout is not fully customized.
The AMP version works best with default templates and not cloud templates. That’s why we integrated it with the Mobile theme plugin.
The feedback from our clients about AMP was negative and it is not used anymore, that’s why we didn’t add more customization options.
Thank you for understanding!
