Please look at the AMP ads, the inline ads not active, i have try many setting and reload lot of post, but there are no ads in my inline. there are 5 slot, 3 of them not visible. there are only two that visible, one is (the header ads or the top ads, i dunno which one of it that visible) and the bottom ad visible. when i deactivate amp plugin, all of my link in google search become 404.. how to redirect the amp to non amp… my viewer is down because of it.. I shall use AMP plugin again after the ads fixed.
Hello miss-nanny,
Please notice that if you want to use Ads for AMP version, all of these must be AMP compatible. Please access your Adsense account and create amp compatible ads for the amp version of your site: https://support.google.com/adsense/answer/7183212?hl=en -> https://www.ampproject.org/docs/reference/components/amp-ad
