Are you referring to the mobile theme homepage? The mobile theme homepage will be different than the desktop page https://tagdiv.com/mobile-theme-automatic-optimization-for-mobile-newspaper-theme/
That is the case for the mobile theme + AMP homepage as well.
If you want to display extra content in the mobile homepage, enter it in the mobile editor https://prnt.sc/udesye
The same has to be done for all pages, you must enter content in the mobile editor for them, that content will be displayed on mobile and mobile + AMP.
If you have more questions let me know.
Hello Simon,
My settings : Mobile Theme + Amp
And there is content in mobile editor for homepage you can check https://prnt.sc/udexhg
But its still not visible on tsotsi.com/?amp
Unfortunatelly i have one more problem in updates section https://prnt.sc/udjb5t
when i click update there is an error : https://prnt.sc/udjby8
it means you dont have permission to do that
i sent my license code to contact@tagdiv.com
if you can help i ll be really glad
thank you
I believe I have found the problem, it seems that disabling the front mobile page grid in the theme panel https://prnt.sc/ue2c70 causes the content in the movile eidtor to not be displayed as well.
Could you enable the top front page grid and check if the content is also displayed? Let me know. I will make some more tests as well.
How can i delete on the top these 2 posts?
I dont want to show these https://prnt.sc/ue2lit
I removed the URLs.
I also removed the grid, please check again https://prnt.sc/ueoaun Should be the way you want it now.
How to show ads in mobile header screen.
(using Magazine pro templates)
This reply was modified 6 years by
tofikpardeshi.
Hi tofikpardeshi, the Magazine pro demo is not a Newsmag demo is a Newspaper demo, therefore you need to set your question in Newspaper forum, not in Newsmag.
-> https://forum.tagdiv.com/forum/newspaper/
