[AMP PROBLEMS with Newspaper 9.6.1 – TAGS missing or incorrect]
since we upgraded the theme to version 9.6.1 (friday March 22nd) we experienced lots of AMP problems, getting many many errors from Google Search Console. Testing the pages with AMP Validator we get the results you can see in the screenshot.
https://bit.ly/2HSqrFB
https://bit.ly/2U1zgUV
How could we fix?
Thank you so much!
Roberto Capetti
This problem is usually caused by some plugins that create some conflict ( untested plugins), please deactivate all non theme plugins, also if you are using child theme ( or cache plugin ), clear all cache deactivate the cache/child plugin and try again.
Please make sure that you set the amp like in our documentation
How to Make an AMP Ready Website with Newspaper Theme -> https://tagdiv.com/amp-newspaper-theme/
Mobile Theme: Automatic Optimization for Mobile with Newspaper Theme -> https://tagdiv.com/mobile-theme-automatic-optimization-for-mobile-newspaper-theme/
-> https://validator.ampproject.org/
Also please check some similar topics -> https://forum.tagdiv.com/topic/amp-problem-4/
Hi Calin,
we tried to switch off a bunch of plugins, but we got worst results, now the pages have 7 errors instead of 3.
Here a link you can inspect
https://validator.ampproject.org/#url=https%3A%2F%2Fwww.cisiamo.info%2Feconomia%2Fconcorsi%2F2019%2F03%2F27%2Fconcorsi-pubblici-aprile-2019-bandi-scadenza%2F%3Famp
Thanks a lot!
Please make a test, create a new post ( simple one, only some text and 1-2 images ) and text this post with amp validator, see if the results are the same.
Also please check this documentation about amp
AMP validation errors -> https://www.ampproject.org/docs/troubleshooting/validation_errors
Resolving validation errors -> https://www.ampproject.org/docs/fundamentals/converting/resolving-errors
AMP validation error: “The mandatory text inside tag ‘head > style[amp-boilerplate]’ is missing or incorrect.” -> https://stackoverflow.com/questions/51755852/amp-validation-error-the-mandatory-text-inside-tag-head-styleamp-boilerpla
