Hi, I’m having problems with AMP.
I want to use my menu on AMP but I can’t see it.
My header logo has poor resolution and I want to use on center.
My Adsense codes aren’t working.
I want to translate Leave a comment section.
Last problem is footer logo. My footer logo has poor resolution and wrong color.
Our AMP plugin does not show a menu, this is not implemented at the moment. However it might receive a menu in future plugin updates.
This is similar to the Yoast SEO website AMP version
– https://yoast.com/social-media-optimization-with-yoast-seo/amp/
The logo that will be used in the header will be the one set for mobile
– https://www.screencast.com/t/s0TSQ7WO
Try testing with different logo sizes and check if the logo is still blurry. It should be exactly as uploaded. I used in a test a logo like this
– https://www.screencast.com/t/ECwm3YPVof7
– https://www.screencast.com/t/7qjwLciCK0tR
It was centered in the first version of the plugin, but a decision has been made to left align it in the latest plugin version. A setting has not been added to choose it’s location.
As long as you are entering valid codes in the desired locations of the AMP plugin, there should be no problem with the ads
– https://support.google.com/adsense/answer/7183212?hl=en
– https://www.screencast.com/t/Kd7fibQixj
Be sure to test on mobile or mobile emulators to see the ads, on desktop they might not appear.
The same footer logo from desktop will be displayed in the AMP version. So it should look the same.
The plugin is at it’s beginning, it will receive more options in future updates, suggestions are welcome as well. It has no translation settings at the moment. It could only be translated with modifications to the plugin files if required
– https://www.screencast.com/t/pqaEwqwdRyb
