AMP – Small Issue Needs Fixing
Hi Tagdiv,
I am hoping you can help me fix this little issue I am experiencing.
I recently activated the “TagDiv Amp Plugin” and all seems to be working almost perfectly.
Take this post for example: https://gadgetgang.com/what-gaming-in-the-future-will-look-like/
You can see I can enable / Disable AMP on this post see here: http://prntscr.com/l2l8ci
I have it enabled and can now view the post from an AMP perspective from going to: https://gadgetgang.com/what-gaming-in-the-future-will-look-like/?amp
However, is there not anyway to have it without the QUESTION MARK (?amp) and just have /amp
I think this is causing issues as Google has still not picked up my amped pages and I am receiving this message in Google Webmaster Tools: http://prntscr.com/l2l93a
Also if i test it on: https://search.google.com/test/amp and place this URL: https://gadgetgang.com/what-gaming-in-the-future-will-look-like/ it says it finds it as /amp but then it doesnt work but if i place /?amp (with the question mark) it works fine.
Is there a fix for this that I can apply to resolve the issues I am having, I hope I have explained myself sufficiently.
Hope to hear from you soon,
Dan
resave permalinks to make the /amp endpoint active.
You Sir are the man! Thanks a lot Simchris such a simple fix!
