Hi All,
I have a problem with the version AMP on mobile, when I use chrome or safari on iPhone, but I’ve checked with android smartphone also.
The problem is on homepage, when i click on Menu icon or search icon they don’t expand, is like I cannot click on them!
In particular the problem arises when i found my site on google and open it through this link
https://www.google.com/amp/s/www.davidpinto.it/%3Famp
How I can resolve it?
thank you so much
David
Please make sure that you are running the latest AMP version. Also please check for a plugin conflict. Disable all the plugins except AMP and Tagdiv ones, clear your cache and test to see if this works.
Also, are you using another plugin for an amp or the one that is included in the theme package?
Hi Anamaria,
thanks I lot! I have resolve it, I had an old plugin
“AMP JSON Validation Error Workaround” that probably it was the cause of this problem.
Now it does work.
thank you
David
