Analytics mobile stats problem with Mobile theme and AMP
I’ve installed tagdiv mobile theme and amp plugin following your recommendations. It’s a very good job ! But i now have a problem with mobile google analytics stats. Before i had a bounce rate average on mobile 86 % and page views per session 1,28. But now with tagdiv mobile theme and amp plugin, bounce rate is 1,96 % and page view per session 2,32, it’s not possible.
My website is : https://www.guide-du-chien.com/
Can you check if there is a probleme with analytic code please ?
On Dekstop and tablets, analytics stats are good, no change.
Is possible to take some time until the rate average on mobile will increase, because there was some changes in mobile theme and amp, so you’ll need to star again from the began, if you check today you average rate this will be bigger the before.
