anchor ad problem with mobile menu
I added the anchor ad in my webpage. It looks cool like this https://www.screencast.com/t/tz1QoSGfRe but when I close it header it not moving upside and it stays like this https://www.screencast.com/t/o5bT5Arg but the main problem is when I open the menu section some area looks white and 2 or 3 sections doesn’t appear like this https://www.screencast.com/t/SYm8iWCIAR so I need to solve this problem. Can you help about this?
My website is : teknovv.com
Thank you
I can’t see that ad at the moment – http://prntscr.com/ngri2j
Maybe something could be done with CSS. Could be the same issue as in this topic
– https://forum.tagdiv.com/topic/mobile-theme-menu-issue-2/ so that code may work.
Yep, that is the same problem and I solved it now 🙂 thank you very much
Hi simon, updated the theme but I have the same problem again. I used the code but it not working. Can you help me
Hello !
We need to take a look and see what happened there.
– admin url and credentials
Our team will take a look !
