An obvious way to do this is to simply use Big Grid 4 multiple times as needed and let infinite load handle the rest, but my concern is that doing so will result in far too many queries running something like a dozen loops on the initial load of the home page.
So my questions are:
I assume #2 can be done via the Theme API but the documentation isn’t clear on grids, only blocks and modules. I definitely want something that can be protected through updates without a child theme, but a couple of edits per update is fine too. This is still slightly experimental but big grid 4 with grid style #4 looks amazing and shows a lot of promise, so I’m willing to commit to a fair bit of work to make this happen. I need some advice on getting started though.
A solution would be to create a new block which uses module mx5 used on Big Grid 4 – http://screencast.com/t/sKkpOyylx
Just check how the other blocks are built – http://screencast.com/t/ExHy1I5QEz
You need something like row > mx5 + mx5 > /row – http://screencast.com/t/iGlHrTgO9
And check the api documentation on blocks – https://forum.tagdiv.com/td_api_blockadd/
Module mx5 can be used on the new block so there’s no need for a new one.
And you may probably need some custom css.
Hope this helps.
