apply individual templates to products
Hello, I need to create two product templates. That is, use a global one for most products and another template to assign it to other products that have different characteristics, how can I do it? Thanks
Go to the cloud templates and install the product templates you need: https://app.screencast.com/gOlacfzyvXbei
From there, you can select the global template as well. View the products you want another template for and assign it manually like this: https://app.screencast.com/oqfJj5FvOKj35  (Click on the correct template, and the green color will appear, which means that template is assigned to that product.).
