Arabic right-to-left issues
The image in the link below sows an Arabic article, and punctuation marks are appearing on the wrong side. I placed them inside a red and blue circle. They both should be on the other end of the line. How to fix this please?
https://app.screencast.com/5NzGCO6mODnHe
Hello @janabi!
I can see that your issue is solved: https://prnt.sc/cH6S7m_YFyIM
Sorry for the late reply.
It has been partially solved. I have to do the rtl manually, which is little bit impractical. If the theme is rtl theme, shouldnt acceot rtl by default without extra plugins?
https://app.screencast.com/ZIRmzvwn2ICbn
Hello @janabi!
We have some RTL demos that were created by hand for this purpose using custom code: https://prnt.sc/ccPYeDT6mvKv
So, you can correct any other demo in the same way.
I know you do and I am using the theme you mentioned !! Not sure what your response means!
Cant you see I am already using the RTL theme you mentioned? I am using RTL theme you pointed in your screenshot but the RTL feature is not working 100%. So could you please tell me how to fix the RTL issue?
Check the screenshot below as an example
https://app.screencast.com/242HCoIEsQ5sY
best regards
Hello @janabi!
Add the CSS code in Newspaper -> Theme panel -> Custom code -> Custom CSS:
.tdm_block.tdm_block_inline_text .tdm-descr { text-align:right!important;}
