Article Box Depricated: Code Left
It looks like the update removed some of the article box choices. I have the html coding in that space but I am unable to access it to remove it. It’s on the hamepage in the right sidebar, under the search tab. https://atlantachristianvoice.com.
This is an element from Standard Pack plugin, and it appears there because you uninstall the plugin.
You can fix this by editing the page with TagDiv Composer and save it without any modification. TagDiv Composer will automatically remove it.
