Hi johnkruse,
Please make sure that you are using the latest version of the theme ( v10.2) and WordPress, also if you are using cache plugin, please clear all cache after you make some changes in theme panel or with tagDiv Composer.
If the problem is still there, please provide some more details and some screenshots or a link were I can check this situation.
Please make first a full backup to your website and database and check our documentation for theme update -> https://tagdiv.com/update-newspaper-theme/
Hope this will help you!
