Article inline ads not working with simple post template pro
Hi, I have added the adsense code for all ads fields for single post template pro as explained in the last topic and as shown in image in the following link, but ads still not shown in article top, bottom and inline ads. please help.
https://androidhands.com/wp-content/uploads/2020/08/Annotation-2020-.png
I have solved it, the cause of this problem that i have use the wrong adsense code. there are different types of adsense codes according to the ad type, i have used the code for site ad type, but the discovered that there is another codes for article inline ad and i got this code for adsense and past it in cloud post templates and it worked successfully.
