1) Article meta info not showing in flex block. Just only showing the category.
2) When i make change something and then refresh the site it stay same for a long time as previous setting.
1. First make sure the general meta you want to display is enabled in the general block settings
– https://www.screencast.com/t/yHHNBnc1DfS
Then in the flex block setting you can enable/disable the meta
– https://www.screencast.com/t/whPPwhWI
If all of these settings are enabled and the meta is not displaying, please provide a link to the website where this is happening so I can take a look.
2. That sounds like a caching issue. Try to clear the cache of your plugin or server provided cache after you make a setting. That should refresh the website. The theme by itself has no caching.
