Article problem
Hello everyone, I have a problem viewing the articles. In my site the localhost works perfectly but online (even if it is under maintenance) the display is incorrect …. the divider bars are all overlapped at the top of the page and are not used as separators …. Which one can be the problem?
Hello !
Please make sure that you do not have a plugin conflict, please deactivate ALL non theme-related plugins, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
I have disabled all plugins and when I view the article the shortcodes [one_half] – [/ one_half] – [one_half_last] – [one_half_last] are displayed as text and the [dividers] and [divider_top] are not entered. I imagine that these shortcodes depend on the WP Shortcode by MyThemeShop plugin. What I don’t understand is that the localhost has the same plugins active and everything works correctly.
I solved the problem by disabling the WP Tab Widget plugin (in localhost it doesn’t give me any problems so I still don’t understand the reason) that generates a Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 72 bytes) in …
Hello !
Unfortunately that plugin is not tested with Newspaper Theme and we cannot offer support for it.
We are sorry for the inconvenience !
